Hi
We had an physical C3010 server with an issue with the iLO card generating a lot of log that wasn't removed during normal clean up nor aggresive clean up jobs. In that case we got the motherboard of the server replaced as the iLO interface was in a stuck state and we could not log in to it.
But I have also run into disk issues on various versions of ClearPass 6.11.x.
Best Regards
Jonas Hammarbäck
Aranya AB
Original Message:
Sent: May 16, 2024 06:45 AM
Subject: System running with low disk space
Hi Alexs-nd,
Did you manage to solve this issue? We are facing the same since the upgrade to ClearPass 6.11.8.
Thanks in advance!
Lex
Original Message:
Sent: Nov 15, 2023 06:38 AM
Sadly the cluster is running 6.11.5 :-(
Sent from my iPhone
Original Message:
Sent: 11/15/2023 5:00:00 AM
Subject: RE: System running with low disk space
This is a well known bug on 6.11.0 , we solved this with upgrade to 6.11.5 after support recommendation.
Shpat | ACEP | ACMP | ACCP | ACDP |
-Just an Aruba enthusiast and contributor by cases
Original Message:
Sent: Nov 15, 2023 03:20 AM
CPPM 6.11.5
4 node cluster,
two nodes are generatibng evenet messages saying System is running loq on disk space. Agressive cleanup of /var/log$ will be initiated when the available disk space falls below 20% Current available disk space 25%
These cluster nodes happen to host my primary and secondary insight databases.
System monitor shows 61/820 GB used , no swap space used
Had an issue with these boxes before wher they ran out of /var/log space and needed a reboot to get them working again. Problem is that 1 of them is the master publisher
Is this a 6.11 thing?
A
