Tacacs Access to Mellanox from Clearpass
  • 1.  Tacacs Access to Mellanox from Clearpass
    Posted May 06, 2019 02:45 AM
    Hi all
    has anyone succsefully configures TACACs on a mellanox switch with clearpass, I need help , cannot get it right . tried with cisco settings but it didnt work........
    Sven
  • 2.  RE: Tacacs Access to Mellanox from Clearpass
    Posted May 08, 2019 05:27 AM
    Could you be a bit more specific on where you currently struggle?
    Have you been able to configure the Mellanox switch in such a way, that TACACS requests are being sent to ClearPass?
  • 3.  RE: Tacacs Access to Mellanox from Clearpass
    Posted May 29, 2019 02:11 PM
    I am having the same problem.  I can create a tacacs service and import it but I'm not sure what the services has to have in it for the mlnx-exec.
    So I log in, it says I pass authenticaiton and the alert is shown and I get re-prompted for the password.
  • 4.  RE: Tacacs Access to Mellanox from Clearpass
    Posted Jun 17, 2019 03:53 PM
    BTW, I solved this issue.  I added this to the Tacacs Dictionary and specified this service in the profile.  I probably don't need the attribute, just the service...
        <TacacsServiceDictionary dispName="mlnx-exec:unknown" name="mlnx-exec:unknown">
          <ServiceAttribute dataType="String" dispName="protocol" name="protocol"/>
        </TacacsServiceDictionary>
  • 5.  RE: Tacacs Access to Mellanox from Clearpass
    Posted Jun 24, 2019 09:21 AM
    Hi All , Thanks Phillip for your input , I figured it out , I had to export the TACACS dictionary first then add to the xml and import it back.
    Works like a charm.. Your a legend. Thank you
  • 6.  RE: Tacacs Access to Mellanox from Clearpass
    Posted Jun 24, 2019 09:23 AM
    Hi All and Phillip , it works perfectly Thank you
    I exported the tacacs dictionary added the script you gave and it worked .
    Your a legend thank you
