TACACS+ and ACS v4
  • 1.  TACACS+ and ACS v4
    Posted Mar 27, 2014 04:15 PM
    I can configure TACASC+ in ACS v4?
    Currently I have it configured, but it does not works.
  • 2.  RE: TACACS+ and ACS v4
    Posted Mar 27, 2014 04:18 PM
    Is this a question or comment.
    You will need to provide a lot more information.
    Device
    Name
    Firmware
    errors in device
    CPPM
    Version
    screen shots of errors in access tracker
    ETC.
    TACACS
    Commands
    ETC....
  • 3.  RE: TACACS+ and ACS v4
    Posted Mar 28, 2014 04:36 AM
    The conf in Controller:
    aaa server-group "TACACS-SVR-GROUP"
    auth-server TACACS-SERVER-A
    aaa authentication-server tacacs "TACACS-SERVER-A"
    host "X.X.X.X"
    key XXXXXXXXXXXXX
    tcp-port 4949
    session-authorization
    aaa authentication mgmt
    enable
    aaa tacacs-accounting server-group TACACS-SVR-GROUP mode enable command all
    The error in ACS:
    service denied - service=aruba protocol=common
  • 4.  RE: TACACS+ and ACS v4
    Posted Mar 28, 2014 03:12 PM
    If you're stuck with TACACS+, a valid alternative might be using RADIUS. You can download Aruba VSAs for ACS from this link:
    http://support.arubanetworks.com/ToolsResources/tabid/76/DMXModule/514/EntryId/115/Default.aspx
    Regards
  • 5.  RE: TACACS+ and ACS v4
    Posted Apr 01, 2014 10:08 AM
    What add value?
  • 6.  RE: TACACS+ and ACS v4
    Posted Apr 02, 2014 04:54 PM
    If you want administration access you need to pass back to the controller the following: Aruba-Admin-Role = root
