last person joined: 8 hours ago
TACACS+ Authorization
  • 1.  TACACS+ Authorization
    Posted Apr 18, 2017 06:07 PM
    Hi guys,
    We have a CPPM running 6.6.5.93747.
    I've created a service to Authenticate and Authorize admin user to login in Palo Alto Networks firewall using TACACS+. The Authenticate step are ok... The user can login on the Firewall using CPPM as TACACS+ Server. The problem is in Authorization. I cannot enforce admin group privilege.
    The PA firewall sent some parameter on authentication proccess:
    Authorization request sent with priv_lvl=1 user=tacacsuser service=PaloAlto protocol=firewall
    I've attached Access Tracker "Authorizations" and "Alerts" screens with the errors.
    I need sent back the attribute "PaloAlto-Admin-Role" with name of the user profile.
    Authorization support using TACACS+ are new in PA firewall. It was inclued in the latest major version released a month ago.. So, I don't know if someone else will have the same problem as me. Therefore, if you have other kind of scenario that I can copy, I appreciate.
    Thank you.
    Paulo R.
  • 2.  RE: TACACS+ Authorization
    Posted Apr 18, 2017 06:12 PM
    What version of PANOS are you running?
  • 3.  RE: TACACS+ Authorization
    Posted Apr 18, 2017 06:14 PM
    Hi Tim,
    PANOS 8.0.1.
    Here a PA Doc of a configuretion in Cisco ACS using Authorization profiles:
    https://live.paloaltonetworks.com/t5/Configuration-Articles/Palo-Alto-Management-Access-through-TACACS/ta-p/149144
  • 4.  RE: TACACS+ Authorization
    Posted Apr 18, 2017 06:23 PM
    Hi..
    I found the issue.. As PANOS sent "service=PaloAlto protocol=firewall " in Authorization, we need create a TACACS+ Services called PaloAlto:firewall with "PaloAlto-Admin-Role" string.
  • 5.  RE: TACACS+ Authorization
    Posted Apr 18, 2017 06:40 PM
    Yes, that's correct. Attached is the TACACS+ dictionary.
    Attachment(s)
  • 6.  RE: TACACS+ Authorization
    Posted Mar 27, 2018 04:47 PM
    I seem to be failing the authorization part too (Authentications show passed, but Firewall denies me access)
    I added the dictionary listed in this post and dumped my SHELL profile for a PaloAlto:Firewall version that had the PaloAlto-Admin-Role included, and return "superuser" , but man, can't figure out why its rejected.
    PANOS 8.0.7, 6.7.2 Clearpass
