TACACS + cppm VIP = no Access Tracker logging
  • 1.  TACACS + cppm VIP = no Access Tracker logging
    MVP EXPERT
    Posted Jan 25, 2022 09:18 AM
    I use  TACACS to auth to our Airwave  appliance and our switches. using CPPM 6.10.2
    This all works just fine when I point the devices at the IP address associated with the mgmt interface on our cluster  members and I can see entries in  Access-Tracker for my TACACS logins.
    I'm now looking at configuring  TACACS+ auth for all our  ArubaOS 6.5 mobility controllers using  clearpass VIPs  instead of  the interface  IP addresses. This also works but I'm unable to  see any access-tracker  entries for the auths
    1). In the  service list I can see the hit count for my mobility controller tacacs service incrementing  every time I log onto my test controller
    2). In Monitoring/Accounting I can see and entry for my  cppm (admin) username
    3). No entry in Access-Tracker for my auth request
    Access-tracker is set to display all auths from all cluster members
    I'm going to test this  by  setting up the controller to use a physical ip address, but do suspect I'll then see  the auth records in access tracker ... unless there's another config item  that needs changing
    A
    Alex Sharaz
  • 2.  RE: TACACS + cppm VIP = no Access Tracker logging
    MVP EXPERT
    Posted Jan 25, 2022 09:26 AM
    ... and changing to using  an interface IP has made no difference, still cant see an access tracker record for  the mobility controller
    Alex Sharaz
  • 3.  RE: TACACS + cppm VIP = no Access Tracker logging
    Posted Jan 26, 2022 07:30 AM
    Could it be that you have selected the Access Tracker on a specific node, or zone which does not include the server where the TACACS+ authentication ends up on?
    If you can authenticate, and it does not show in Access Tracker, that is something I would worry about. If there are no filters active, and you are sure that you see the Access Tracker for the node where the authentication happens, please open a TAC case.
  • 4.  RE: TACACS + cppm VIP = no Access Tracker logging
    MVP EXPERT
    Posted Jan 26, 2022 08:11 AM
    Replicated service on home system, same clearpass config   But against an ArubaOS 8.9  MM/md setup ... works just fine
    Access tracker shows. Tacacs for other services , just not this one
    Also noticed that if I want to crest a new service , instead of. Being asked to select service type , it hits direct to. Configuring a radius one
    A
    Sent from my iPhone
  • 5.  RE: TACACS + cppm VIP = no Access Tracker logging
    Posted Jan 31, 2022 10:02 AM
    Could it be that you don't have active Access Licenses? TACACS+ requires Access Licenses.
  • 6.  RE: TACACS + cppm VIP = no Access Tracker logging
    MVP EXPERT
    Posted Jan 31, 2022 10:06 AM
    Nope,
    Lots of active access licenses
    Going to raise a TAC case after I’ve upgraded to 6.10.3 tomorrow
    Could be something really silly
    A
  • 7.  RE: TACACS + cppm VIP = no Access Tracker logging
    MVP EXPERT
    Posted Feb 03, 2022 11:01 AM
    Annoyingly, upgraded from 6.10.2 -> 6.10.3 …… and TACACS auth from the controller are now visible in Acces-Tracker.
    Whether it was the reboot that did it or the upgrade, don’t know but everything working fine now … well from a TACACS point of view
    A
