TACACS+ for wifi client authentication
  • 1.  TACACS+ for wifi client authentication
    Posted Dec 14, 2016 06:01 AM
    Hi everybody,
    I'm trying to use TACACS for wifi client authentication on my wifi LAN. However, looking at the documentation/tutorial/forum, it looks like that TACACS can be used only to allow user to the managemt GUI/Shell of Aruba controller
    Can you please let me know if my understandig is right or not?
    BTW I have got an ARUBA 7005
    Federico
  • 2.  RE: TACACS+ for wifi client authentication
    Posted Dec 14, 2016 06:19 AM
    You will want to use RADIUS for WiFi client authentication. TACACS+ is used for providing access control (etc) to the administrative interfaces (GUI/CLI).
    Cheers
    James
