TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
  • 1.  TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Sep 24, 2012 08:21 PM
    TACACS service logs in tracker as success when doing AAA test server against it, but actual attempted authentication fails with this in the controller's log (and no Access Tracker entry):
    Sep 25 19:06:27 :124004:  <DBUG> |authmgr|  RX (sock) message of type 10, len 324
    Sep 25 19:06:27 :124004:  <DBUG> |authmgr|  aal_authenticate user:khall vpnflags:0
    Sep 25 19:06:27 :124004:  <DBUG> |authmgr|  unknown user=192.168.1.119, method=Management
    Sep 25 19:06:27 :124004:  <DBUG> |authmgr|  aal_authenticate server_group:default
    Sep 25 19:06:27 :124004:  <DBUG> |authmgr|  Select server for method=Management, user=khall, essid=<>, server-group=clearpass-TACACS-srvr-gp, last_srv <>
    Sep 25 19:06:27 :124004:  <DBUG> |authmgr|   server=clearpass, ena=1, ins=1 (1)
    Sep 25 19:06:27 :124038:  <INFO> |authmgr|  Selected server clearpass for method=Management; user=khall,  essid=<>, domain=<>, server-group=clearpass-TACACS-srvr-gp
    Sep 25 19:06:27 :199802:  <ERRS> |authmgr|  tacplus.c, tacplus_api:49: Invalid authentication protocol for TACACS+
    Sep 25 19:06:27 :124066:  <INFO> |authmgr|  Administrative User Authentication Successful: username=khall IP=192.168.1.119 auth server=clearpass
    Sep 25 19:06:27 :124003:  <INFO> |authmgr|  Authentication result=(null)(-1), method=Management, server=clearpass, user=192.168.1.119
    Sep 25 19:06:27 :124004:  <DBUG> |authmgr|  Auth server 'clearpass' response=-1
    Sep 25 19:06:27 :125027:  <DBUG> |aaa|  mgmt-auth: khall, failure, , 0
    Sep 25 19:06:27 :125022:  <WARN> |aaa|  Authentication failed for User khall, Logged in from 192.168.1.119 port 56645, Connecting to 192.168.1.2 port 4343 connection type HTTPS
    It says it's successful @ "Sep 25 19:06:27 :124066" but then gives "Authentication result=(null)(-1)" which ultimately results in fail. Any ideas?!?
  • 2.  RE: TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Sep 24, 2012 09:18 PM
    Please open a support case so they can get to the bottom of this...
  • 3.  RE: TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Apr 09, 2013 10:00 AM
    I have a similar issue using Tacacs for management with MSCHAPV2.
    With PA¨P, it's working but when I activate MSCHAPV2. I get the following log :
    Apr 9 15:58:50 :124038: <INFO> |authmgr| Selected server ACS-REC for method=Management; user=air, essid=<>, domain=<>, server-group=ACS_Local
    Apr 9 15:58:50 :199802: <ERRS> |authmgr| tacplus.c, tacplus_api:49: Invalid authentication protocol for TACACS+
    Apr 9 15:58:50 :124066: <INFO> |authmgr| Administrative User Authentication Successful: username=air IP=10.101.115.219 auth server=ACS-REC
    Apr 9 15:58:50 :124003: <INFO> |authmgr| Authentication result=(null)(-1), method=Management, server=ACS-REC, user=10.101.115.219
    Apr 9 15:58:50 :125022: <WARN> |aaa| Authentication failed for User air, Logged in from 10.101.115.219 port 53475, Connecting to 10.63.220.110 port 22 connection type SSH
    Is there any bug fixes ?
  • 4.  RE: TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Apr 09, 2013 10:01 AM
    Well,
    what does the rejection say on the CPPM side?  That is the key to your issue...
  • 5.  RE: TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Apr 09, 2013 10:10 AM
    We are not using CPPM but a Cisco ACS 5.0.
    The issue is very similar.
  • 6.  RE: TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Apr 09, 2013 10:11 AM
    @pel wrote:
    Well,
    What message does the Cisco ACS show?  The Cisco ACS sends back the "1" response to the controller, so that is the key to your issue.
    Aruba should support TACAS+ with MsChap from 6.1.3.0 onwards...
  • 7.  RE: TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Apr 09, 2013 10:30 AM
    hello,
    There is no log because there is no authentication start requets.
    (Aruba620) #show aaa authentication-server tacacs statistics
    TACACS Server Statistics
    Statistics ACS-REC
    Accounting Requests 0
    Authentication Start Requests 1
    Authorization Requests 0
    Authentication Responses(Pass) 1
    Authentication Responses(Fail) 0
    Authorization Responses(Pass) 0
    Authorization Responses(Fail) 0
    Accounting Responses(Pass) 0
    Accounting Responses(Fail) 0
    Total Login Successes 1
    Total Login Failures 0
    Timeouts 0
    AvgRespTime (ms) 84
    Uptime (d:h:m) 0:0:37
    (Aruba620) #
    The one we have here is when I do PAP.
  • 8.  RE: TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Apr 09, 2013 10:56 AM
    Got it.  What version of ArubaOS Code is this?
  • 9.  RE: TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Apr 09, 2013 11:01 AM
    6.1.3.2
  • 10.  RE: TACACS Issue from Controller on 6.1.3.4 auth'ing against CPPM 5.2.0
    Posted Mar 01, 2014 01:09 AM
    Anybody ever find a fix for this.  I have 60 controllers ver 6.1.3.7 going to CPPM 6.3.x and I have 2 that will not authenticate.  I see nothing in the access tracker.  Support told me there was a bug and to upgrade to 6.1.3.11 on the controller so i upgraded one of them but it did not help.
    Please let me know if any of the above issues were resolved and what the fix was.
