"TCLAS flow deleted" as Termination Reason in voice calls over Wireless
  • 1.  "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 16, 2016 06:46 AM
    Hi all.
    We have deployed voice over wireless with Cisco 7921 and 7925 IP Phones and an Aruba6000 controller (ArubaOS 6.4.x) with a mix os AP 105, 124 and 215 and a SSID dedicated only for voice. Lately some users complained of the calls finishing just after picking up the phone or after only a few seconds and in the Dashboard of the controller (Dashboard > UCC > QoS Details, for example) we are noting that many calls terminate after only a few seconds (in some cases after 1 second) with reason "TCLAS flow deleted".
    I've been unable to found some Aruba document refering to such term, although it seems clear that it's related with QoS/TSPEC. The voice VAP has an WMM Traffic management profile applied, and a VoIP Call Admission Control profile applied to the groups that contain such VAP (the SSID profile has an High-throughput SSID Profile, by the way). The profiles are configured accordingly, as far as possible, the guidelines of Cisco for the 792x phones (http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/7925g/7_0/english/deployment/guide/7925dply.pdf). Here are the profiles:
    SSID Profile
    Parameter Value
    SSID enable Enabled
    ESSID XXXXX
    Encryption wpa2-psk-aes
    Enable Management Frame Protection Disabled
    Require Management Frame Protection Disabled
    DTIM Interval 2 beacon periods
    802.11a Basic Rates 12 24
    802.11a Transmit Rates 12 18 24
    802.11g Basic Rates 12 18 24
    802.11g Transmit Rates 12 18 24
    Station Ageout Time 1000 sec
    Max Transmit Attempts 3
    RTS Threshold 2333 bytes
    Short Preamble Enabled
    Max Associations 64
    Wireless Multimedia (WMM) Enabled
    Wireless Multimedia U-APSD (WMM-UAPSD) Powersave Enabled
    WMM TSPEC Min Inactivity Interval 0 msec
    Override DSCP mappings for WMM clients Disabled
    DSCP mapping for WMM voice AC 56
    DSCP mapping for WMM video AC 40
    DSCP mapping for WMM best-effort AC 24
    DSCP mapping for WMM background AC 8
    Multiple Tx Replay Counters Disabled
    Hide SSID Disabled
    Deny_Broadcast Probes Disabled
    Local Probe Request Threshold (dB) 0
    Disable Probe Retry Enabled
    Battery Boost Disabled
    WEP Key 1 N/A
    WEP Key 2 N/A
    WEP Key 3 N/A
    WEP Key 4 N/A
    WEP Transmit Key Index 1
    WPA Hexkey N/A
    WPA Passphrase ********
    Maximum Transmit Failures 25
    EDCA Parameters Station profile N/A
    EDCA Parameters AP profile N/A
    BC/MC Rate Optimization Disabled
    Rate Optimization for delivering EAPOL frames Enabled
    Strict Spectralink Voice Protocol (SVP) Disabled
    High-throughput SSID Profile NO-802.11n
    802.11g Beacon Rate default
    802.11a Beacon Rate default
    Video Multicast Rate Optimization default
    Advertise QBSS Load IE Disabled
    Advertise Location Info Disabled
    Advertise AP Name Disabled
    802.11r Profile N/A
    Enforce user vlan for open stations Disabled
    Enable OKC Disabled
    High-throughput SSID profile "NO-802.11n"
    Parameter Value
    High throughput enable (SSID) Disabled
    40 MHz channel usage Disabled
    Very High throughput enable (SSID) Disabled
    80 MHz channel usage (VHT) Disabled
    BA AMSDU Enable Enabled
    Temporal Diversity Enable Disabled
    Legacy stations Allowed
    Low-density Parity Check Enabled
    Maximum number of spatial streams usable for STBC reception 1
    Maximum number of spatial streams usable for STBC transmission 1
    MPDU Aggregation Enabled
    Max received A-MPDU size 65535 bytes
    Max transmitted A-MPDU size 65535 bytes
    Min MPDU start spacing 0 usec
    Short guard interval in 20 MHz mode Enabled
    Short guard interval in 40 MHz mode Enabled
    Short guard interval in 80 MHz mode Enabled
    Supported MCS set 0-23
    VHT - Supported MCS map 9,9,9
    VHT - Explicit Transmit Beamforming Disabled
    VHT - Transmit Beamforming Sounding Interval 25 msec
    Maximum VHT MPDU size 11454 bytes
    Maximum number of MSDUs in an A-MSDU on best-effort AC 2 MSDUs
    Maximum number of MSDUs in an A-MSDU on background AC 2 MSDUs
    Maximum number of MSDUs in an A-MSDU on video AC 2 MSDUs
    Maximum number of MSDUs in an A-MSDU on voice AC 0 MSDUs
    Virtual AP profile
    Parameter Value
    AAA Profile XXXXX
    802.11K Profile default
    Hotspot 2.0 Profile N/A
    SSID Profile XXXXX
    Virtual AP enable Enabled
    VLAN XXXXX
    Forward mode tunnel
    Allowed band all
    Band Steering Disabled
    Steering Mode prefer-5ghz
    Dynamic Multicast Optimization (DMO) Disabled
    Dynamic Multicast Optimization (DMO) Threshold 6
    Drop Broadcast and Unknown Multicast Enabled
    Convert Broadcast ARP requests to unicast Enabled
    Authentication Failure Blacklist Time 3600 sec
    Deny inter user traffic Disabled
    Deny time range N/A
    DoS Prevention Disabled
    HA Discovery on-association Enabled
    Mobile IP Disabled
    Preserve Client VLAN Disabled
    Remote-AP Operation standard
    Station Blacklisting Enabled
    Strict Compliance Disabled
    VLAN Mobility Disabled
    FDB Update on Assoc Disabled
    WMM Traffic Management Profile XXXXX
    WMM Traffic management profile XXXXX
    Parameter Value
    Enable Shaping Policy true
    Voice Share 70 %
    Video Share 10 %
    Best-effort Share 10 %
    Background Share 10 %
    VoIP Call Admission Control profile XXXXX
    Parameter Value
    VoIP Call Admission Control Enabled
    VoIP Bandwidth based CAC Disabled
    VoIP Call Capacity 12
    VoIP Bandwidth Capacity (kbps) 2000
    VoIP Call Handoff Reservation 20 %
    VoIP Send SIP 100 Trying Disabled
    VoIP Disconnect Extra Call Disabled
    VOIP TSPEC Enforcement Disabled
    VOIP TSPEC Enforcement Period 1 sec
    VoIP Drop SIP Invite and send status code (client) 486
    VoIP Drop SIP Invite and send status code (server) 486
    Any idea about what could be causing the "TCLAS flow deleted"?
    Regards.
  • 2.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 16, 2016 07:48 AM
    Remove your WMM traffic management profile.
    Remove your VOIP Call admission control profile.
    See if that fixes it.
    You have too many options enabled to say what it could be.
  • 3.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 16, 2016 03:01 PM
    Going along with what Colin is suggesting, are you using Airwave?  You could use the Call Volume table on the UCC Dashboard to determine if you're hitting your max of 12 simultaneous calls on an AP.
  • 4.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 17, 2016 03:54 AM
    Hi all and thanks for the replies.
    I removed WMM traffic management and VOIP Call admission control profiles, but the problem persists, perhaps at a slightly minor frequency.
    Yes, I'm using Airwave and I've found that in some very specific cases and moments some APs gets more than 12 concurrent calls, although don't seems to correlate with the "TCLAS flow deleted" messages and it don't occurs with enough frequency to explaining the messages.
  • 5.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 17, 2016 05:41 AM
    xosema,
    Please PM me your email address so I can send you a link to send me your logs.tar so I can take a look and come up with a recommendation.
  • 6.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 17, 2016 08:09 AM
    A call is released with reason code as TCLAS_FLOW_DELETED if AP sends ageout for the client due to inactivity.  What kind of voice clients are these (what voice protocol is in use)?  I have looked over your logs and I have a few questions...
  • 7.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 17, 2016 08:40 AM
    The voice clientes are Cisco 792x IP phones using SCCP.
    It's strange that the "TCLAS flow deleted" appears due to client ageout: "Station Ageout Time" is configured to 1000 seconds and I've verified that, for the same phones, several TCLAS terminations occurs frequently in intervals under that 1000 seconds, some times even in intervals of few .
    Feel free to ask.
  • 8.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 17, 2016 08:55 AM
    Please send me the logs of the controller with the issue.  I only got the logs for the master controller.
  • 9.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 17, 2016 09:04 AM
    I've sended you the logs of the right controller now, sorry!
  • 10.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 18, 2016 07:03 AM
    Hi.
    Unfortunately after aplying yesterday the suggested changes (disabling the "dot11a-traffic-mgmt-profile" and "dot11a-traffic-mgmt-profile" profiles in the AP Group and enabling "Drop Broadcast and Multicast" in the other SSIDs of the same AP Group) the TCLAS messages remains. Any idea?
    I'm gonna try to review the configuration both in the phones themselves as in the Call Manager searching for patterns to verify if the problem only occurs in some of them and if some kind of configuration matches the problematic ones.
    Regards.
  • 11.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 18, 2016 07:06 AM
    At this point, I would open a TAC case.  They can review your logs in detail and perhaps come up with a few reasons why you are having that issue.
  • 12.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 18, 2016 07:10 AM
    Thanks for the advice :-)
  • 13.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 18, 2016 07:16 AM
    Sorry about that...
  • 14.  RE: "TCLAS flow deleted" as Termination Reason in voice calls over Wireless
    Posted Mar 21, 2016 07:32 AM
    Hi all.
    I think I've found what was the problem before opening a case in the TAC. Reviewing carefully the configuration I found that the parameter "interference-immunity" in both radio profiles ("dot11a-radio-profile" and "dot11g-radio-profile") for the AP Groups that included the voice SSID was set to "3" instead of the default "2". Probably the value was changed a time ago during some tests. Since returning to the default value the TCLAS messages have dissapeared.
    To change the "interference-immunity" parameter to the default value:
    rf dot11a-radio-profile "TEST-a"
    interference-immunity 2
    rf dot11g-radio-profile "TEST-g"
    As explained for example in http://community.arubanetworks.com/t5/Technology-Blog/Hotspot-deployments-Part-II-Interference-mitigation-guidelines/ba-p/35669, the "interference-immunity" value should not changed lightly.
    Regards.
