last person joined: 7 hours ago
Teap and Received error TLV from client
  • 1.  Teap and Received error TLV from client
    Posted Mar 29, 2023 11:04 AM
    I'm testing SCEPMan and an Azure/Intune only device.
    I'm using TEAP for the method with a modified EAP-TLS that doesn't check for authorization as it's just pulling from the Endpoint Repo and Intune extension
    Though I've only configured machine authentication atm (is that ok?)
    The only error I'm getting now is "teap: Received error tlv 2002 from client"
    Would anyone have suggestions on this? I am assuming it's cert related but the client machine has the client cert and trusted root cert from SCEPMan. The root cert from SCEPMan was added to Clearpass
  • 2.  RE: Teap and Received error TLV from client
    Posted Apr 03, 2023 09:43 AM
    From the RFC
    2002  Unexpected TLVs Exchanged
    What type and version is your Client?
    What is the ClearPass version?
    Does the same certificate work with EAP-TLS?
  • 3.  RE: Teap and Received error TLV from client
    Posted Apr 03, 2023 09:52 AM
    Hi Herman,
    This was just to test an Azure/Intune only device, so I ended up adding PEAP (with EAP-TLS as the inner method) to my existing wired service which was just EAP-TLS.
    I changed the client to use PEAP and same certificates and it worked fine.
    I'll revisit TEAP again some other time. Thanks for your response.
