[Technote] AP Hardware Information
  • 1.  [Technote] AP Hardware Information
    Posted Jan 29, 2014 05:27 PM
    Hello everyone!
    Here im putting you all the AP hardware information which is really useful when you comparing vs the other brands hardwre, and well Aruba Hardware is superior! :)
      	       SDRAM memory	FLASH memory	CPU
    RAP-3WN(P)	128MB	16MB	AR9344 560MHz
    IAP-104/105	128MB	16MB	AR7161 680MHz
    IAP-114/115	256MB	32MB	AR9550 700MHz
    IAP-134/135	256MB	16MB	88F6560 1.6GHz Single Core
    IAP-224/225	512MB	32MB	P1020 800MHz Dual Core
    AP93H	         64 MB  16MB	AR7242 390MHz
    RAP109	        128MB	32MB	AR9344 560Mhz
    IAP93	         64MB	16MB	AR7242 390MHz
    You  can see this info yourself by looking it at the console when the AP is booting up.
    Its a interesting info i think we should know.
    This also let you know  which APs fit best for select as instant cluster master!
    Cheers
    Carlos
  • 2.  RE: [Technote] AP Hardware Information
    Posted Feb 01, 2014 12:38 PM
    Good that you compliled these infromation, definetely will come in handy.:smileyhappy: Good work.
  • 3.  RE: [Technote] AP Hardware Information
    Posted Mar 26, 2015 05:31 AM
    how mutch ram and wich cpu does the AP215 and 205 have?
  • 4.  RE: [Technote] AP Hardware Information
    Posted Mar 27, 2015 07:41 AM
    Carlos, a few more for your list
    AP-228        512MB    32MB    FSL-P1020
    AP-277        512MB    32MB    FSL-P1020
    AP-274/5     512MB    32MB    FSL P1020
    AP-214/5     256MB    32MB    FSL-P1010
    AP-205/H    128MB     32MB    BCM53014A
    AP-103        128MB    32MB     AR9344
    AP-103H      64MB     16MB      AR9344
    RAP-155/P   256MB   32MB     88F6560
    regards
    -jeff
  • 5.  RE: [Technote] AP Hardware Information
    Posted Feb 01, 2016 10:32 AM
    Do you know RAM/FLASH for 320 series?
    Cheers,
    Marek
  • 6.  RE: [Technote] AP Hardware Information
    Posted Feb 01, 2016 11:55 AM
    I will get with PLM to verify what I haveand will update this post...
  • 7.  RE: [Technote] AP Hardware Information
    Posted Feb 21, 2016 07:31 AM
    256MB SDRAM 128MB Flash
  • 8.  RE: [Technote] AP Hardware Information
    Posted Jun 12, 2018 11:08 PM
    Hi, what aboute ram, memory flash and cpu in the AP207 product?
  • 9.  RE: [Technote] AP Hardware Information
    Posted Jun 13, 2018 12:55 AM
    207 Series Campus APs have 256MB SDRAM and 128MB FLASH.
    CPU is part of the BCM47452 SOC, ARM A7 at 900MHz.
    Why do you need to know?
