Tell me about the 3g/4g capabilities on Aruba IAP-115
  • 1.  Tell me about the 3g/4g capabilities on Aruba IAP-115
    Posted Feb 20, 2014 03:29 PM
    Hi Airheads!
    I was just wondering what the cellular capabilities of the Aruba IAP-115 are. On my controller, in the corner, it says "cellular provider: no modem installed." After doing some Googling, I guess you can plug a USB aircard from ATT, VZW, or Sprint into the access point? What does this do, exactly? How does it work?
    Thanks!
  • 2.  RE: Tell me about the 3g/4g capabilities on Aruba IAP-115
    Posted Feb 20, 2014 03:31 PM
    This allows you to use a 3G/4G/LTE broadband cards as a primary or backup uplink. You can find more information (including which devices are supported) in the Instant 4.0 user guide on page 193.
    http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=13053
