Wired Intelligent Edge
Telnet/SSH idle timeout problem
  • 1.  Telnet/SSH idle timeout problem
    Posted Apr 25, 2022 10:52 AM
    Greetings, this is my first post here. We use OpenVAS to run vulnerability scans on 2930F access switches and a 3810M Core switch. The problem is that the OpenVAS would fill all the sessions without terminating any of them. We would have to manually go and kill the sessions with a console connection. I added the console idle-timeout 60 and it did kick me out in 1 minute but the next time the vulnerability scan was ran, the same happen again.
    I don't know if that is the correct command or there is a bug on the firmware.
    Thanks in advance for the help.
    Edgar Murray
  • 2.  RE: Telnet/SSH idle timeout problem
    Posted Jul 22, 2022 09:52 AM
    I'm having this same issue. Did you find a resolution?
  • 3.  RE: Telnet/SSH idle timeout problem
    Posted Jul 25, 2022 10:13 AM
    Make an exception to not scan the switch from OpenVAS.
    You could also open a support case to find out in which state OpenVAS leaves the session, and if there is a command to change the behavior on the switch. What may be happening is that OpenVAS does not login, but leaves the SSH (or telnet) session open. If it is telnet traffic, disable telnet on the switch, which you should do anyway for security hardening.
