Aruba Central
Template syntax guide
This thread has been viewed 32 times
  • 1.  Template syntax guide
    Posted Dec 08, 2021 02:01 AM
    Hi all,
    Is there documentation available about the syntaxes you can/can't use in Aruba Central Templates.
    For example I am interested in operators like AND & OR.
    Hope someone can help
    Danny van der Aa
  • 2.  RE: Template syntax guide
    MVP GURU
    Posted Dec 08, 2021 08:09 AM
    Is this what you are looking for?
    https://help.central.arubanetworks.com/2.5.4/documentation/online_help/content/nms/maintenance/template-variables.htm
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: Template syntax guide
    Posted Dec 08, 2021 09:19 AM
    Hi Dustin,
    Also this is useful, but not what i ment.
    I am looking for the operators i can use.
    So the if statements, but also the operators like AND & OR.
    For example i would like to use something like
    %if a=1 or b=2%
       description test
    %endif%
    Danny van der Aa
  • 4.  RE: Template syntax guide
    Posted Dec 10, 2021 09:25 AM
    Check this search. There is that page posted above, but another one with the syntax explained and an example config using it.
    Unsure if an OR function is supported.
