For connected clients in AirWave, at top of diagnostics page, you see the network connection path for that client: client > SSID > AP > switch > etc. For us, this used to terminate with the Aruba controller and then our core switch as the last two entries.
Two months ago, we had a temporary snafu where a switch had two ports looped on accident. Now, that access layer switch and its upstream distribution switch show to the right of the core switch in the network path for all connected clients.
How does AirWave generate this path, and is there a way to reset it to clear something like this? I don't believe it is related to the new Topolgy feature that was introduced in a recent version - we do not have LLDP enabled on all switches, so that map is sparse for us.
