I can only imagine there is some mismatch between the stop-start-parity setting for your serial connection, but have not see this before.
Is it just with your Mac and this (model of) switch?
Or also with different serial client and this model of switch?
Or also with your Mac and other switches?
Original Message:
Sent: Sep 22, 2023 06:48 PM
Subject: Terminal Freezes
On my Mac I have an issue while using Terminal to connect to a 6300M. It will freeze up and not display the letter e in all words.
Am I missing something?
I use the command screen tty.usbserial-### 115200.
Thank you
