Hello ,
By default, up to 24 lines can be displayed on a screen. You can change the limit by using the screen-length screen-length command.
You can also disable pausing between screens of output for the current session. Then, all output is
displayed at one time and the screen is refreshed continuously until the final screen is displayed.
Use below command:
HPE# screen-length disable
Thanks!
