Terminating GRE tunnels on VRRP
  • 1.  Terminating GRE tunnels on VRRP
    Posted Jul 18, 2012 05:41 AM
    Hi All,
    Is it now possible to terminate GRE tunnels on the VRRP IP address?
    I believe I read it in some release note but can someone confirm please?
    James
  • 2.  RE: Terminating GRE tunnels on VRRP
    Posted Jul 18, 2012 10:01 AM
    yes.
  • 3.  RE: Terminating GRE tunnels on VRRP
    Posted Jul 18, 2012 01:21 PM
    I've been doing this for a while with good results. Never knew it was in doubt??? Can't remember the first version I did it in, but it was ages ago...
    Cheers!
  • 4.  RE: Terminating GRE tunnels on VRRP
    Posted Jul 18, 2012 01:42 PM
    Thanks guys.
    FYI The controllers are currently on 6.1.2.5.
  • 5.  RE: Terminating GRE tunnels on VRRP
    Posted Jul 18, 2012 05:10 PM
    I've been doing it since early 3.x through 6.1.3.2, no worries.
  • 6.  RE: Terminating GRE tunnels on VRRP
    Posted Jul 20, 2012 04:14 AM
    Working fine now. I was setting the source address on the master as the VRRP address which didn't work. When I changed it to the controllers IP it worked fine.
  • 7.  RE: Terminating GRE tunnels on VRRP
    Posted Apr 11, 2014 05:32 PM
    I'm confused now.
    Tunnels from local controllers back to the headquarters have been rock-solid until I went from single master to VRRP-pair redundant master. Now they seem to forget to tunnel traffic.
    I left the tunnel configs exactly the same on the master and the local controllers, with the addition that I've duplicated the master's settings on the backup master -- that is both of them list the tunnel source as the master (virtual) IP.
    Should I set the tunnels on the masters as sourced from their IP real addresses?
    I don't want duplicate tunnels from locals to both masters, I just want one tunnel to the master-in-charge, so do I leave the locals pointing to the VRRP address?
