Test what features are disabled in lower power modes
  • 1.  Test what features are disabled in lower power modes
    Posted Sep 23, 2021 11:22 PM
    I'm wanting to test what is disabled on various IAP models when they run at various power levels. For example, if I ran an IAP-555 on a single 802.1at, is there a command to see what features are disabled?
  • 2.  RE: Test what features are disabled in lower power modes
    Posted Sep 24, 2021 09:21 AM
    "show ap debug system-status" should tell you the current power status
    Power Status
    Item Value
    Power Supply : POE
    LLDP Power : (not available)
    Current Operational State : No restrictions
    HW POE status : POE
    The datasheet specifically calls out what is enabled/disabled at various levels of power:  https://www.arubanetworks.com/assets/ds/DS_AP550Series.pdf
    IPM can be enabled to determine what is disabled when there is a low power event.  Attached is a cheatsheet on Intelligent power management
    Attachment(s)
  • 3.  RE: Test what features are disabled in lower power modes
    Posted Sep 26, 2021 11:30 PM
    Thanks that's what I was after!
