> what TFTP server you use
That was not the problem. http://tftpd32.jounin.net/ and the "3com TFTP server E4200_24G_Switch_v.1.05_3Com_TFTP_Server_1.05.exe" actually BOTH work now.
The answer was hidden somewhere else :-)
"Administration ... Backup configuration ..." only worked after I had pressed "Save configuration" for the first time, which was "invisible" because it was not hidden in a sub-menu, but in at the top level. Hidden in plain sight, so to say.:
"Unit1 save configuration flash:/3comoscfg.cfg successfully"
[Looks as if the configuration was never saved before, somehow strange behaviour, isn't it?]
Now it works flawlessly to store the configuration remotely:
- Backup from: Unit ID 1 4200G
- Saved to the TFTP server: IP Address192.168.42.155 Remote filename:cfg.cfg
- Backup complete.
Yippieh. Thank you very much!
