Wired Intelligent Edge
TFTP Problems 2530 and 2930F
  • 1.  TFTP Problems 2530 and 2930F
    Posted Jan 26, 2018 04:04 AM
    I'm having problems to TFTP image files using a 2530 switch.
    My TFTP server is located on another subnet.
    If I TFTP from my Cisco switches on the same network, it's working fine.
    However, I actually can TFTP configuration files using the 2530.
    Is this a software bug?
    HP-2530-8G-PoEP# show system information
    Status and Counters - General System Information
    System Name : HP-2530-8G-PoEP
    System Contact :
    System Location :
    MAC Age Time (sec) : 300
    Time Zone : 0
    Daylight Time Rule : None
    Software revision : YA.16.05.0004 Base MAC Addr : e0071b-340ca0
    ROM Version : YA.15.20 Serial Number : CN68FP53DN
    Up Time : 18 hours Memory - Total : 67,108,864
    CPU Util (%) : 1 Free : 39,058,240
    IP Mgmt - Pkts Rx : 27,512 Packet - Total : 3022
    Pkts Tx : 27,407 Buffers Free : 2895
    Lowest : 2884
    Missed : 0
    HP-2530-8G-PoEP# copy tftp config new_config.cfg 172.18.20.51 J9774A.cfg
    HP-2530-8G-PoEP#
    HP-2530-8G-PoEP# show config
    config
    new_config.cfg
    HP-2530-8G-PoEP# copy tftp flash 172.18.20.51 YA_16_04_0011.swi secondary
    The secondary image will be deleted.
    Continue (y/n)? y
    000M Request failed.
    HP-2530-8G-PoEP#
    HP-2530-8G-PoEP# show log -r
    Keys: W=Warning I=Information
    M=Major D=Debug E=Error
    ---- Reverse event Log listing: Events Since Boot ----
    W 01/01/90 18:31:15 00137 tftp: Request failed.
    Thanks!
    Oscar Bengtsson
  • 2.  RE: TFTP Problems 2530 and 2930F
    Posted Jan 26, 2018 05:41 AM
    Is there any logging on the TFTP server?
  • 3.  RE: TFTP Problems 2530 and 2930F
    Posted Jan 26, 2018 05:56 AM
    I'm using atftp, the output shows that there is actually being blocks transfered but then it stops. Tried changing block sizes back and forth.
    Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: Creating new socket: 172.18.20.51:58760
    Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: Serving YA_16_05_0004.swi to 10.202.0.10:3150
    Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: received RRQ <filename: YA_16_05_0004.swi, mode: octet, blksize: 1416>
    Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: blksize option -> 1416
    Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: sent OACK <blksize: 1416>
    Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: received ACK <block: 0>
    Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: sent DATA <block: 1, size 1416>
    Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: received ACK <block: 1>
    Jan 26 11:50:23 KST-LAB-TFTP-SERVER atftpd[2864]: sent DATA <block: 2, size 1416>
    Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: timeout: retrying...
    Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: sent DATA <block: 2, size 1416>
    Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: recvmsg: Connection refused
    Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: tftpd_file.c: 979: recvfrom: Connection refused
    Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: Aborting transfer
    Jan 26 11:50:28 KST-LAB-TFTP-SERVER atftpd[2864]: Server thread exiting
    Jan 26 11:51:33 KST-LAB-TFTP-SERVER atftpd[2864]: socket may listen on any address, including broadcast
  • 4.  RE: TFTP Problems 2530 and 2930F
    Posted Jan 30, 2018 02:59 AM
    Worked when using tftpd64 on my windows machine, no idea why it doesn't work on Ubuntu.
  • 5.  RE: TFTP Problems 2530 and 2930F
    Posted Apr 11, 2020 05:17 PM
    Hi lads,
    I ran into a similar problem with my 2930F switches. I am building a zero touch deployment including a firmware update configured via the DHCP options. I ran into the problem that the first three packets of the firmware were transferred and then the switch sent an ICMP Destination Unreachable/Port Unreachable. The switch retries to transfer four times and then aborts and continues to load the configuration file.
    I have found out that this is only done if the current firmware of the switch matches the firmware to load. Only if the firmware is a different one loading it is successful. Tested with upgrade from version WC.16.07.0003 to WC.16.10.0005.
    After the switch has booted I am still able to just copy the same firmware over the flash primary without any issues. I am using tftpd-hpa version 5.2+20150808 on ubuntu18.04 LTS.
    I am posting this here because when analyzing this I stumbled across this thread. I can also thereby confirm that tftpd-hpa is working with the HP switches.
