try the following (from 9300 manual):
USING THE CLI
To initiate transfers of configuration files to or from a TFTP server using the CLI, enter one of the following
commands:
copy startup-config tftp <TFTP-IP-ADDR> <FILENAME>
- Use this command to upload a copy of the startup configuration file from the Routing Switch to a TFTP server.
copy running-config tftp <TFTP-IP-ADDR> <FILENAME>
- Use this command to upload a copy of the running configuration file from the Routing Switch to a TFTP server.
copy tftp startup-config <TFTP-IP-ADDR> <FILENAME>
- Use this command to download a copy of the startup configuration file from a TFTP server to a Routing Switch.</FILENAME></TFTP-IP-ADDR></FILENAME></TFTP-IP-ADDR></FILENAME></TFTP-IP-ADDR>
