Wired Intelligent Edge
TFTP upload fails
  • 1.  TFTP upload fails
    Posted Mar 01, 2011 05:00 PM
    I did backed up the startup configuration of a HP procurve 2510G-24 (Software revision Y.11.08) on a USB flash drive.
    I am trying to upload this config file to a HP 2650 (revision H_10_83). The 2650 is used as a backup switch, and I would like to be able to configure it rapidly with the configuration setup of other HP switches that we have, in case one switch like the 2510g-24 fails.
    When I try to upload the 2510G-24 startup file to the 2650 using TFTP, the upload fails. Why ?
    TLswt# copy tftp startup-config 129.121.236.5 sw-503-1239f-01
    Device may be rebooted, do you want to continue [y/n]? y
    00000K Wrong file.
    TLswt#
    Uploading a startup file that was backed up on the 2650 (to the USB flash) back to the same 2650 works fine.
    P.S. This thread has been moved from from Switches, Hubs, Modems (Legacy ITRC forum) to ProCurve / ProVision-Based. -HP Forum Moderator
    #tftp
  • 2.  RE: TFTP upload fails
    Posted Mar 01, 2011 05:45 PM
    In the config, there is a product ID. The switch looks at that info and decides whether or not it can load it.
    During the tftp of a config file, the switch reads the config file and if the ID in the config does not match the product, no upload.
    You can modify the config with appropriate ports, ID, etc and then load it.
    hth...Jeff
    fyi:
    3500yl - ; J8692A
    3500 (not yl) - ; J9471A
    2510 - ; J9019A
  • 3.  RE: TFTP upload fails
    Posted Mar 02, 2011 12:52 PM
    Thank you,
    this did it. What you have to do is to change the first line of the startup file to match the HP procurve on which you want to load the startup config.
    For example:
    In my case if I want to TFTP upload a startup config file to a 2510G-24, then the first line of my file should be:
    ; J9279A Configuration Editor; Created on release #Y.11.08
    In my case if I want to TFTP upload a startup config file to a 2650, then the first line of my file should be:
    ; J4899B Configuration Editor; Created on release #H.10.83
  • 4.  RE: TFTP upload fails
    Posted Mar 04, 2011 06:39 AM
    how do you change the config file? same problem here
  • 5.  RE: TFTP upload fails
    Posted Mar 04, 2011 12:31 PM
    you first download the config file from your switch, let's say a 2510 using tftp (for example: 2510# copy startup-config tftp 192.35.44.77 startfile), you then edit with a text editor like notepad or wordpad or other linux text editor. You then change the line on top of the config file. You save the file.
  • 6.  RE: TFTP upload fails
    Posted Feb 06, 2014 06:48 AM
    Hi, sorry to open an old thread, but I'm trying to update my firmware and have hit this problem.
    I've got 6 switches, but one will not update and I think it's because the first line of the config reads:
    ; HWID.0 Configuration Editor; Created on release #K.12.16
    Trouble is, when I follow steps in this post, I can't upload a revised startup config as I get the same error:
    00000K Wrong file.
  • 7.  RE: TFTP upload fails
    Posted Mar 07, 2014 09:44 AM
    You also need to edit the model number that you see after any module types in the config. Example below (in red).
    ; J9146A Configuration Editor; Created on release #W.15.08.0012
    module 1 type j9146a
    ; J9148A Configuration Editor; Created on release #W.15.08.0012
    module 1 type j9148a
  • 8.  RE: TFTP upload fails
    Posted Sep 04, 2015 11:25 AM
    thanks! i had some garbage at the begining of my file i didnt notice. cleaned it up and it worked.
