The AP 205 Heats
  • 1.  The AP 205 Heats
    Posted May 06, 2015 06:14 AM
    Hi all,
    I have noticed that the IAP 205 Heats a lot , and that aussi also when there is no user connected .
    is That normal ?!
    #AP205
  • 2.  RE: The AP 205 Heats
    Posted May 06, 2015 07:17 AM
    Yes, APs tend to be warm to hot.
    Tim
  • 3.  RE: The AP 205 Heats
    Posted May 06, 2015 07:18 AM
    Raouf,
    I assume you're noticing most of the heat from the black backplate? The backplate of the AP 205 is actually used as a heatsink to move heat away from internal components, so noticing heat from this surface is actually a good thing. We’ve done numerous tests analyzing the temperature of the components in normal and worst-case use, and these all operate well within their specified range. The MTBF is excellent for this AP.
    Best regards,
    Madani
