Hello
I need install the AP IAP-205-RW my question is this AP working in mode standalone? or I need configure the other firmware or realice the other process for converted this ap in mode standalone because the cliente dont have controller.
Thanks for your help.
Regards.
If the part number is "IAP"-XXX-XX, then yes it is running Instant OS; and will not require a controller.
Thanks for your information is great!
Is the same the AP-205H-MNT1 because i need install the two ap in the same network 2 AP IAP-205-RW and 2 AP-205H-MNT1.
Thanks four your help.
Regards
if you are copying the name exactly correct and it is AP-205H-MNT1 then that is a mountingkit and that isn't the actual AP.
if it is a AP-205H-ROW then you need a controller, an actual controller and not the IAP-... if it is IAP-205H-ROW you are fine.
finally this section is for Aruba Applications, so questions on APs go here: http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/bd-p/unified-wired-wireless-access and IAPs go here: http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/bd-p/IAP
