The ARUBA controllerless cluster seem have unstable!
  • 1.  The ARUBA controllerless cluster seem have unstable!
    Posted Dec 30, 2019 05:30 AM
    Hi!
    Can anybody help me in this situation? After we deploy one IAP325 and one IAP215 ( each of them on different switch ) in cluster controllerless mode, our network switches is seem unstable:
    • The uplink of the edge switch connect to the core switch is down/up in unexpect time ( random ), when trace the log of the two IAP it show it lose connect to each other and each of them is consider master and after two or three minutes the problem is resolved itself.
    The problems cause the degrade of our infra network ( the uplink is down cause all of the switches of this branch can't accessable ). I am very new in ARUBA wifi networking so is there anyone can help me how to troubleshoot this situation?
  • 2.  RE: The ARUBA controllerless cluster seem have unstable!
    MVP EXPERT
    Posted Dec 30, 2019 05:41 AM
    Is the uplink to the core stable again when you shutdown both APs ?
    Start troubleshooting from the lowerst ISO layer up.
    • What is your ArubaOS instant release version
    • What is your switch type and firmware version
    • How is it connected to the coreswitch, LACP link aggregation or not
    • Is spanning-tree enabled
    • can you share the edgeswitch loggiing  "show logging -r".
    • can you share the uplink interface statistics "show interface #.
    First thing i think about is you probaly create some mesh point between both APs. Take also a look at this topic https://community.arubanetworks.com/t5/Controllerless-Networks/IAP-315-STP-Blocked/td-p/440040
    If this is a urgent issue please open a TAC case by Aruba Support.
  • 3.  RE: The ARUBA controllerless cluster seem have unstable!
    Posted Dec 31, 2019 03:54 AM
    Hi mkk!
    Here are the info for your requests:
    • The problems are random ( We monitor the up/down by ping every 30s and see the problems auto resovled in ~2 minutes ). If we shutdown both APs , the users cannot connect to our site to work because most of them is using mobile devices. ( We maybe consider it if the situation is worse )
    - Start troubleshooting from the lowerst ISO layer up.
    What is your ArubaOS instant release version?
    ARUBA83-c5:ba:9a# show version
    ArubaOS (MODEL: 325), Version 8.4.0.5
    Website: http://www.arubanetworks.com
    (c) Copyright 2019 Hewlett Packard Enterprise Development LP.
    Compiled on 2019-10-22 at 12:32:12 UTC (build 72830) by p4build
    FIPS Mode :disabled
    AP uptime is 6 days 18 hours 40 minutes 23 seconds
    Reboot Time and Cause: AP rebooted Tue Dec 24 00:43:08 UTC 2019; System cmd at uptime 33D 15H 29M 33S: Image Upgrade Successful
    ARUBA80-ce:13:e2# show version
    ArubaOS (MODEL: 215), Version 8.4.0.5
    Compiled on 2019-10-22 at 13:00:19 UTC (build 72830) by p4build
    FIPS Mode :disabled
    AP uptime is 6 hours 11 minutes 41 seconds
    Reboot Time and Cause: AP rebooted Mon Dec 30 13:11:09 UTC 2019; System cmd at uptime 1D 1H 20M 44S: master transitioned to local (new master 10.10.10.83, uplink flaps 0, max beacon miss 21), uptime from being master 29 seconds.
    What is your switch type and firmware version?
    CORE SPINE ( Dell S6000-ON - Cumulus 3.3.2 ) <-> Leaf216 Switch ( N1524-Firmware 6.3.2.4 ) ( Port7-ARUBA80 )
    <-> Leaf218 Switch ( N1548-Firmware 6.3.2.4 ) ( Port17-ARUBA83 )
    How is it connected to the coreswitch, LACP link aggregation or not?
    Leaf216 - No Aggregation
    Leaf218 - LACP Link aggreation with two ten gigabitethernet uplink
    Is spanning-tree enabled?
    Yes the spanning tree is enabled and configure to RSTP mode.
    can you share the edgeswitch loggiing "show logging -r".?
    The log is very long so i upload as file for you investigate.
    can you share the uplink interface statistics "show interface #.?
    leaf216#show interfaces tengigabitethernet 1/0/3
    Interface Name................................. Te1/0/3
    SOC Hardware Info.............................. BCM56150_A0
    Link Status.................................... Up /None
    Keepalive Enabled.............................. FALSE
    Err-disable Cause.............................. None
    VLAN Membership Mode........................... Trunk Mode
    VLAN Membership................................ (1),2-4096
    MTU Size....................................... 1518
    Port Mode [Duplex]............................. Full
    Port Speed..................................... 10000
    Link Debounce Flaps............................ 0
    Auto-Negotation Status......................... Off
    Burned MAC Address............................. E4F0.047A.D8BC
    L3 MAC Address................................. E4F0.047A.D8BD
    Sample Load Interval........................... 300
    Received Input Rate Bits/Sec................... 438544
    Received Input Rate Packets/Sec................ 483
    Transmitted Input Rate Bits/Sec................ 1079648
    Transmitted Input Rate Packets/Sec : .......... 226
    Total Packets Received Without Errors.......... 10797877379
    Unicast Packets Received....................... 6185770825
    Multicast Packets Received..................... 657183560
    Broadcast Packets Received..................... 3954922994
    Total Packets Received with MAC Errors......... 0
    Jabbers Received............................... 0
    Fragments/Undersize Received................... 0
    Alignment Errors............................... 0
    FCS Errors..................................... 0
    Overruns....................................... 0
    Total Received Packets Not Forwarded........... 1756007234
    Total Packets Transmitted Successfully......... 3781030834
    Unicast Packets Transmitted.................... 3767233192
    Multicast Packets Transmitted.................. 4521176
    Broadcast Packets Transmitted.................. 9276466
    Transmit Packets Discarded..................... 0
    Total Transmit Errors.......................... 0
    Total Transmit Packets Discarded............... 0
    Single Collision Frames........................ 0
    Multiple Collision Frames...................... 0
    Excessive Collision Frames..................... 0
    leaf216#show interfaces gigabitethernet 1/0/7
    Interface Name................................. Gi1/0/7
    VLAN Membership................................ (10),1-9,11-4096
    Auto-Negotation Status......................... Auto
    Received Input Rate Bits/Sec................... 1039136
    Received Input Rate Packets/Sec................ 212
    Transmitted Input Rate Bits/Sec................ 376544
    Transmitted Input Rate Packets/Sec : .......... 379
    Total Packets Received Without Errors.......... 2426485149
    Unicast Packets Received....................... 2421299835
    Multicast Packets Received..................... 2108437
    Broadcast Packets Received..................... 3076877
    Total Received Packets Not Forwarded........... 91212
    Total Packets Transmitted Successfully......... 3304052445
    Unicast Packets Transmitted.................... 2538011770
    Multicast Packets Transmitted.................. 43090035
    Broadcast Packets Transmitted.................. 722950640
    Transmit Packets Discarded..................... 345244
    Total Transmit Packets Discarded............... 345244
    leaf218#show interfaces gigabitethernet 1/0/17
    Interface Name................................. Gi1/0/17
    Burned MAC Address............................. E4F0.04D8.9314
    L3 MAC Address................................. E4F0.04D8.9315
    Received Input Rate Bits/Sec................... 2844280
    Received Input Rate Packets/Sec................ 507
    Transmitted Input Rate Bits/Sec................ 385720
    Transmitted Input Rate Packets/Sec : .......... 519
    Total Packets Received Without Errors.......... 1328243746
    Unicast Packets Received....................... 1321948708
    Multicast Packets Received..................... 995783
    Broadcast Packets Received..................... 5299255
    Total Packets Received with MAC Errors......... 109
    Total Received Packets Not Forwarded........... 36336
    Total Packets Transmitted Successfully......... 1714509842
    Unicast Packets Transmitted.................... 1216567650
    Multicast Packets Transmitted.................. 82898299
    Broadcast Packets Transmitted.................. 415043893
    Transmit Packets Discarded..................... 480562
    Total Transmit Packets Discarded............... 480562
    Thank for your sharing info with me, i will look at it. Thanks!
    Attachment(s)
  • 4.  RE: The ARUBA controllerless cluster seem have unstable!
    MVP EXPERT
    Posted Dec 31, 2019 05:52 AM
    Hi Anhdo,
    Please upgrade to ArubaOS Instant 8.5.x.x or 8.6.x.x., your 8.4.x.x release is end-of-support on 31 december 2019, today ;). link
    At the interface 1/0/3 of leaf216 the broadcast frames are 40% of all received frames, thats much to high.
    Did you check the logging of the instant cluster?
    • show log errorlog all
    • show log system all
    I think your option is to open a TAC case on this.
  • 5.  RE: The ARUBA controllerless cluster seem have unstable!
    Posted Jan 02, 2020 02:38 AM
    Hi mkk!
    Wish you a happy new year!
    I cannot do the upgrade to version 8.5.x as you suggest because using the check new firmware version it show nothing ( please see the attach file ).
    About the broadcast packet too much maybe the device is at production line and users test their device by plugin plugout. Anyway, i will note and monitor about this.
  • 6.  RE: The ARUBA controllerless cluster seem have unstable!
    MVP EXPERT
    Posted Jan 02, 2020 05:52 PM
    Hi Anhdo,
    You can download and install the new firmware manualy.
    Firmware can be download form https://asp.arubanetworks.com
    I send you a PM with instructions.
  • 7.  RE: The ARUBA controllerless cluster seem have unstable!
    Posted Jan 03, 2020 02:53 AM
    Hi mkk!
    Thank you for send me the link. I will look at it and do some test before applied into the production line. Hope the situation better. I will update when i have any news. Thanks!
