To close the open Telnet sessions, it is necessary to either access the switch over the serial console port, or else reboot.
By default, ProCurve switches support a total of three open Telnet sessions and do not automatically terminate sessions that were not properly exited.
When you access the switch through a serial console session, issue the command: “kill” at the prompt. This closes the open Telnet sessions. Next, configure an inactivity timer setting that will serve to automatically close inactive Telnet sessions in the future:
ProCurve Switch(config)# console inactivity-timer <0-120 minutes>
ProCurve Switch(config)# write mem
This will ensure that any Telnet sessions that are inadvertently left open in the future will time out of the switch, and ensure that you are able to establish management access as needed.
Thanks and regards
Anurag Thottathil
