"There are irregularities with this CAD document on rf plan, please assist with solution
  • 1.  "There are irregularities with this CAD document on rf plan, please assist with solution
    Posted Feb 26, 2015 04:12 AM
    hi
    please assist, I need to do floor plans as a metter of urgency and i am struglling with the scalling of these floor plans I tried using CAD format which gives correct measurements but the visual rf plan fails to open the floor plan instead i get this error "
    There are irregularites with this CAD document:
    Object of class OdGsModelLayoutHelper can't be cast to OdGsPaperLayoutHelper.
    Perhaps this CAD file does not support Active Layout?
    Please refer to the 'Error' listings in the CAD Info panel for further information."
    thanks
  • 2.  RE: "There are irregularities with this CAD document on rf plan, please assist with solution
    Posted Feb 26, 2015 01:45 PM
    if you import a jpg file and add a scale measure for one a-to-b measurement on your plan you should be able to move forward quickly
