There is probably a simple answer-DHCP option 252
  • 1.  There is probably a simple answer-DHCP option 252
    Posted Jul 23, 2013 01:52 AM
    Can anyone tell me why I can't turn off DHCP option 252 on my 5.0.4.7 controller?
    I go into the DHCP pool context and enter "no option 252". It accepts the input but nothing happens. It is still in the running config and still in the dhcp database.
    I have tried lots of different combinations of syntax but nothing changes it.
    I treid turning off and on the DHCP server on the controller and still nothing.
    Thanks in advance.
  • 2.  RE: There is probably a simple answer-DHCP option 252
    Posted Jul 23, 2013 02:52 PM
    Don't want to leave you hanging here.  Have you opened a TAC case?  If not, I would encourage you to do so.
  • 3.  RE: There is probably a simple answer-DHCP option 252
    Posted Jul 23, 2013 02:56 PM
    Have you tried removing it from the GUI instead ?
  • 4.  RE: There is probably a simple answer-DHCP option 252
    Posted Jul 23, 2013 07:05 PM
    I didn't think the option is available through the GUI. If it is I can't find it.
  • 5.  RE: There is probably a simple answer-DHCP option 252
    Posted Jul 23, 2013 11:54 PM
    Logged a case.
  • 6.  RE: There is probably a simple answer-DHCP option 252
    Posted Jul 24, 2013 12:02 AM
    I noticed that its available on AOS 6.2 and you are running 5.x
  • 7.  RE: There is probably a simple answer-DHCP option 252
    Posted Jul 24, 2013 12:08 AM
    This controller is the master in a master/local environment. Some of the locals are not capable of running version 6. I have downgraded this controller until we can purchase new locals that are capable of runnng version 6.
  • 8.  RE: There is probably a simple answer-DHCP option 252
    Posted Jul 25, 2013 09:43 PM
    In case anyone is curious, Aruba Support replicated this issue in the lab and recommended a workaround.
    Workaround is delete the whole DHCP pool and recreate it without the option.
    The workaround worked.
