Third Party Firewall between 2 controllers
  • 1.  Third Party Firewall between 2 controllers
    Posted Dec 19, 2015 09:10 AM
    i want to configure an IPSec VPN between 2 controlleurs , and i have a small issue.
    between the two controllers i have a Sophos Firewall that do not support IKEv2 , so i need to nat ports to permit the communication between the two device.
    first , is it possible to do it ?
    then , what are the port that I must nat ?
    Regards
  • 2.  RE: Third Party Firewall between 2 controllers
    Posted Dec 19, 2015 09:12 AM
    If it is ipsec and you have "enforce NAT T" (recommended) on the connection you only need UDP 4500.
  • 3.  RE: Third Party Firewall between 2 controllers
    Posted Dec 19, 2015 09:28 AM
    do any one have a tuto for a VPN site to site configuration
  • 4.  RE: Third Party Firewall between 2 controllers
  • 5.  RE: Third Party Firewall between 2 controllers
    Posted Dec 19, 2015 09:51 AM
    and what about IKE port (500)
  • 6.  RE: Third Party Firewall between 2 controllers
    Posted Dec 19, 2015 09:53 AM
    If you use enforce NAT T, you don't need that.
