Thousands of wlsxAPBssidEntryChanged SNMP traps every day
  • 1.  Thousands of wlsxAPBssidEntryChanged SNMP traps every day
    Posted Mar 08, 2017 09:53 AM
    I have integrated my Aruba WLC with the NMS server and having all the default SNMP traps enabled.
    I am seeing over 20,000 SNMP traps  for "wlsxAPBssidEntryChanged "
    What is this SNMP trap exactly for?
    Is it normal to see these many traps for a network comprising of over 300 Access Points?
  • 2.  RE: Thousands of wlsxAPBssidEntryChanged SNMP traps every day
    Posted Mar 08, 2017 10:28 AM
    Traps are nothing but events occured on controller, any chanages occur on controller, it will generate trap and forwared to NMS server if we integrate.
    Default there are around 300 traps enabled on controller and all this traps will be sent to airwave.
    If you dont want to forward all the traps to NMS then we could disable some unwanted traps.
    I have attached snmptraps command list, you need to copy and past the commads on controller in config mode.
    Pavan
    If my post address your question, accept solution and give kudos:)
    Attachment(s)
    txt
    SNMP trap commands1.txt   13 KB 1 version
  • 3.  RE: Thousands of wlsxAPBssidEntryChanged SNMP traps every day
    Posted Mar 08, 2017 11:10 AM
    O_o
    What AOS version?
  • 4.  RE: Thousands of wlsxAPBssidEntryChanged SNMP traps every day
    Posted Mar 08, 2017 11:12 AM
    wlsxAPBssidEntryChanged trap availabe in latest AOS code aswell.
  • 5.  RE: Thousands of wlsxAPBssidEntryChanged SNMP traps every day
    Posted Mar 08, 2017 12:25 PM
    Thanks Pavan for the prompt response and in the interpretation of the stated trap message.
    Before considering to disable certain traps, my worry is to understand the reason behind these may occurances of  "wlsxAPBssidEntryChanged" traps.
    It does not appears to be a normal condition wherein these many traps are generated, right?
    Also could you please share a document that help understand the interpretation of each trap listed in "show snmp trap-list"?
  • 6.  RE: Thousands of wlsxAPBssidEntryChanged SNMP traps every day
    Posted Mar 08, 2017 12:46 PM
    Please find MIB guide which provide details of each trap
    https://community.arubanetworks.com/aruba/attachments/aruba/IAP/152/1/Aruba%20Instant%206.2.0.0-3.2%20MIB%20Reference%20Guide.pdf
    Based on trap count of BSSIDEntryChanged it looks their is continuous change in configuration I would recommand to open TAC ticket to check controller config.
  • 7.  RE: Thousands of wlsxAPBssidEntryChanged SNMP traps every day
    Posted Mar 08, 2017 12:54 PM
    In my previous post i have provided IAP mib guide URL, please find AOS mib guide attached.
    Attachment(s)
    pdf
    ArubaOS_6.1MG.pdf   2.13 MB 1 version
