Till which version of Aruba OS is supported for Aruba 3200 model.
  • 1.  Till which version of Aruba OS is supported for Aruba 3200 model.
    Posted Sep 19, 2013 06:14 AM
    Dear Support,
                               Could you please tell me till which version of Aruba OS is supported for Aruba 3200 model.We are having right now aruba version 6.1.3.4.Also If Aruba 3200 supports the latest version.Please guide us who to upgrade to latest version.
    #3200
  • 2.  RE: Till which version of Aruba OS is supported for Aruba 3200 model.
    Posted Sep 19, 2013 06:23 AM
    The latest version is 6.1.3.10 and if you an memory upgrade you could install 6.3.0.1
  • 3.  RE: Till which version of Aruba OS is supported for Aruba 3200 model.
    Posted Sep 19, 2013 06:27 AM
    Dear Support,
                               I actually dont have any information on memory upgrade.Could you please explain it in short. Also will the Aruba 3200 hardware support 6.3.0.1 after memory upgrade.
  • 4.  RE: Till which version of Aruba OS is supported for Aruba 3200 model.
    Posted Sep 19, 2013 06:55 AM
    In order for the 3200 to support any AOS6.2 and up it requires a memory upgrade .
    See this post :
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/3200-hardware-specs-vs-3200XM/td-p/78554
  • 5.  RE: Till which version of Aruba OS is supported for Aruba 3200 model.
    Posted Sep 19, 2013 07:45 AM
    The part number is 3200-MEM-UG.  It is a memory module that you replace yourself; instructions included.
    And yes, it will run 6.3.0.1; however it does not support the AP Image Preload functionality (neither do the 600s or 3400).
