Time Based SSID Broadcast - Controller and Instant
  • 1.  Time Based SSID Broadcast - Controller and Instant
    Posted Apr 21, 2017 05:47 AM
    Hi All
    I was hoping there is a way to set a SSID to only broadcast at certain times.
    On Controllers I know about the "Deny Time Range" option, however the SSID is still broadcasting during that time, is there a way to set profile to stop broadcasting all together during a specific time?
    On iAP I see there options for Time Range (this under edit for the SSID and expanding Advanced) - however I am unfamiliar with the feature on iAP, setting a time range here will it only broadcast during that time or is it also a Deny like on the Controllers?
  • 2.  RE: Time Based SSID Broadcast - Controller and Instant
    MVP EXPERT
    Posted Apr 21, 2017 06:08 AM
    Hey, it will disable the SSID.
  • 3.  RE: Time Based SSID Broadcast - Controller and Instant
    Posted Apr 21, 2017 07:51 AM
    Awesome THX Zalion
    Is there away to achieve the same on a Controller (3600 and 7210)?
  • 4.  RE: Time Based SSID Broadcast - Controller and Instant
    Posted Apr 21, 2017 08:17 AM
    you can deny connections but the SSID will still be visible.
    You'll configure this under VAP - deny timer range.
    Timer range is configured under Access Control - Timer range
    or conf t, timer-range on the CLI.
    Hope it helps
