Wired Intelligent Edge
Time incorrect / 1hr ahead on Aruba 2930F - Using NTP
  • 1.  Time incorrect / 1hr ahead on Aruba 2930F - Using NTP
    Posted Aug 04, 2019 03:52 PM
    Hi all,
    I'm using NTP on an Aruba 2930F, running the latest firmware. The thing is, my clock is an hour off and I can't understand why. I'm using us.pool.ntp.org which has always been accurate for me.
    NTP configuration is as follows:
    timesync ntp
    ntp unicast
    ntp server-name "us.pool.ntp.org" iburst
    ntp enable
    time daylight-time-rule user-defined begin-date 03/10 end-date 11/03
    time timezone -420
    At the time of this post UTC/GMT is 19:48. I'm in PST so the switch should be 12:48. Yet I'm getting 13:48 from the switch, indicating it's 1hr off/ahead.
    Aruba-Lab-SW1# show time
    Sun Aug  4 13:48:11 2019
    NTP associations look good:
    Aruba-Lab-SW1# show ntp associations
                                NTP Associations Entries
     Remote          St   T    When   Poll  Reach    Delay    Offset   Dispersion
     50.205.244.111  2    u    408    8     3        0.000    0.000    15.87941
    And NTP status:
    Aruba-Lab-SW1# show ntp status
     NTP Status Information
      NTP Status             : Enabled         NTP Mode        : Unicast
      Synchronization Status : Synchronized    Peer Dispersion : 0.00000 sec
      Stratum Number         : 3               Leap Direction  : 0
      Reference Assoc ID     : 0               Clock Offset    : -0.00021 sec
      Reference ID           : 50.205.244.111  Root Delay      : 0.05642 sec
      Precision              : 2**-18          Root Dispersion : 0.04622 sec
      NTP Up Time            : 0d 0h 8m        Time Resolution : 819 nsec
      Drift                  : 0.00000 sec/sec
      System Time            : Sun Aug  4 13:50:38 2019
      Reference Time         : Sun Aug  4 13:38:11 2019
    Aruba-Lab-SW1#
    I'm at a loss. Does anyone have any ideas here? I'm temporarily setting the timezone to -480 as a temporary fix but that doesn't seem right.
    Thanks in advance!
  • 2.  RE: Time incorrect / 1hr ahead on Aruba 2930F - Using NTP
    Posted Aug 04, 2019 04:23 PM
    I redid the configuration you posted without the time daylight settings and the time is what you want, but when we do the time daylight setting, we are automatically within the time frame you entered in your setting (March 10th and ending November 3rd) and with that we have this difference reported.
    Aruba-2930F-24G-PoEP-4SFPP(config)# show ntp status
      Reference Assoc ID     : 0               Clock Offset    : 0.00221 sec
      Reference ID           : 64.22.253.155   Root Delay      : 0.19228 sec
      Precision              : 2**-18          Root Dispersion : 0.07641 sec
      NTP Up Time            : 0d 0h 23m       Time Resolution : 819 nsec
      Drift                  : 0.00001 sec/sec
      System Time            : Sun Aug  4 13:20:53 2019
      Reference Time         : Sun Aug  4 12:45:29 2019
    Aruba-2930F-24G-PoEP-4SFPP(config)# show time
    Sun Aug  4 13:20:58 2019
    Aruba-2930F-24G-PoEP-4SFPP(config)# show run
    Running configuration:
    ; JL255A Configuration Editor; Created on release #WC.16.08.0001
    ; Ver #14:07.6f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:24
    hostname "Aruba-2930F-24G-PoEP-4SFPP"
    module 1 type jl255a
    timesync ntp
    ntp unicast
    ntp enable
    time timezone -420
    snmp-server community "public" unrestricted
    vlan 1
       name "DEFAULT_VLAN"
       untagged 1-28
       ip address dhcp-bootp
       ipv6 enable
       ipv6 address dhcp full
       exit
    Configuration with daylight
      Precision              : 2**-18          Root Dispersion : 0.07773 sec
      NTP Up Time            : 0d 0h 24m       Time Resolution : 819 nsec
      System Time            : Sun Aug  4 14:22:20 2019
      Reference Time         : Sun Aug  4 13:45:29 2019
    Sun Aug  4 14:22:26 2019
    timesync ntp
    ntp unicast
    ntp enable
    time timezone -420
    vlan 1
       name "DEFAULT_VLAN"
       untagged 1-28
       ipv6 enable
       exit
  • 3.  RE: Time incorrect / 1hr ahead on Aruba 2930F - Using NTP
    Posted Aug 04, 2019 07:43 PM
    Ah! - So I realized my mistake. I think what's actually needed (for this to happen automatically) is for me to set the timezone to PST and then set the daylight-time-rule to continental-us-and-canada.
    The correct configuration should be:
    time timezone -480
    time daylight-time-rule continental-us-and-canada
    Since I'm technically in the PST time zone, the switch now uses its internal calendar to set the time zone to PDT which is UCT -7 currently, even though I specified -480 in the config!
