Time Range config on AOS 8
This thread has been viewed 43 times
  • 1.  Time Range config on AOS 8
    Posted Sep 11, 2019 11:27 AM
    This is on the user guide from the version 8.3.0.x
    But the path is still from the version 6.x.
    I looked around but I couldn't find. Where is this configuration on the Version 8 ??
  • 2.  RE: Time Range config on AOS 8
    Posted Sep 11, 2019 11:59 AM
    It is in the Virtual AP profile:
  • 3.  RE: Time Range config on AOS 8
    Posted Sep 11, 2019 12:01 PM
    I know, but I need to customize the time range. That is what I am looking for.
  • 4.  RE: Time Range config on AOS 8
    Posted Sep 11, 2019 12:04 PM
    I need this, but in AOS 8.
  • 5.  RE: Time Range config on AOS 8
    Posted Sep 11, 2019 11:53 PM
    have you tried doing it form the CLI?
    time-range periodic night-hours
        weekday 18:01 to 23:59
        weekday 00:00 to 07:59
    time-range periodic working-hours
        weekday 08:00 to 18:00
  • 6.  RE: Time Range config on AOS 8
    Posted Jun 01, 2022 12:38 AM
    I have the same issue as Heltonb. In the CLI, I can show time-range, but how do I configure it?
    Also, I have been looking for a CLI manual for mobility conductor AOS 8 but with not much luck, would you happen to know where I  can download one?
    Thanks!
    Original Message:
    Sent: Sep 11, 2019 11:53 PM
    Subject: Time Range config on AOS 8
    time-range periodic night-hours    weekday 18:01 to 23:59    weekday 00:00 to 07:59!time-range periodic working-hours    weekday 08:00 to 18:00
  • 7.  RE: Time Range config on AOS 8
    Posted Jun 01, 2022 06:56 AM
    You would have to do this:
    config t
    time-range periodic night-hours weekday 18:01 to 23:59 weekday 00:00 to 07:59 ! time-range periodic working-hours weekday 08:00 to 18:00
