time range not respecting time zone?
  • 1.  time range not respecting time zone?
    Posted Sep 30, 2019 04:35 PM
    I have a network that uses a time range.  Since upgrading to 8.3.0.9_72226 that network stops working at the wrong time.  I had to disable the time range to get that network back up.  The problem might also be the wrong the system time.  It is currently 3:21 PM CT (Chicago, IL, USA),
    show clock says it is
    # show clock
    Current Time :2019-09-30 20:21:23
    I do have ntp setup
    show log iap-bootup | i NTP
    NTP server 172.19.40.1 from configuration
    so I think either the time range is not respecting the time zone or the system is not respecting the time zone.  What do you think?
  • 2.  RE: time range not respecting time zone?
    Posted Oct 03, 2019 03:25 AM
    Show clock should display the local time in your time zone. NTP uses UTC/GMT by standard and it looks like your AP shows the time in UTC.
    Did you set the timezone?
    My 8.5 AP has the following command to verify:
    IAP303H-1a:68# show clock timezone
    Current Timezone
    Country    Timezone  DST Name  DST Recurring
    Amsterdam  UTC+01    CEST      last sunday march 02:00 last sunday october 03:00
    Current Time     :2019-10-03 09:24:21
    and 09:24:21 is my local time. UTC time now is 07:24:21.
  • 3.  RE: time range not respecting time zone?
    Posted Oct 08, 2019 08:40 PM
    #show clock timezone
    Current Timezone
    Central-Time UTC-06 CDT second sunday march 02:00 first sunday novembe r 02:00
    # show clock
    Current Time :2019-10-09 00:38:22
    The current time is 7:38 PM
  • 4.  RE: time range not respecting time zone?
    Posted Oct 08, 2019 09:10 PM
    I just upgraded to ArubaInstant_Centaurus_8.5.0.3_72498 and the problem remains.
    Current Timezone
    Central-Time UTC-06 CDT second sunday march 02:00 first sunday november 02:00
    # show clock
    Current Time :2019-10-09 01:09:02
    The time is 8:09 PM October 8, 2019.
    Is there a way to verify that NTP is working correctly?
