OK, Why does Aruba need to make this so difficult I will never understand. Meraki can do this in 3 clicks. What I have is a cluster in Aruba Central with an SSID. I want this SSID disabled after 5 PM and re-enabled at 7 AM. Time Range Profiles setup is NOT working. I have tried countless number of settings and hours into this to get this to work with still no luck. Can someone PLEASE verify how to get this done.
SSID: IT
Network is NOT hidden and is not disabled under Misc
Time Range Profiles I have set to the specific time of 07:00 - 17:00 and I have chosen to enable and the SSID is still broadcasting. So I figure maybe its a play on words and I choose to Disable the Time Range Profile and STILL the SSID is broadcasting. It is quite iiritating.
I have Verified that my IAP controller VC has the correct TIME and Date and that NTP is enabled.
Please HELP anyone.
