Time restrict connect to IAP Guest Captive Portal
  • 1.  Time restrict connect to IAP Guest Captive Portal
    Posted Dec 01, 2013 05:52 PM
    Hello's
    I have a customer that is providing guest access via the Instant Captive portal. The customer would like to restrict access to the guest SSID during night time. Is it possible to restrict access based on time?
    thanks for your time,
    Blue
  • 2.  RE: Time restrict connect to IAP Guest Captive Portal
    Posted Dec 02, 2013 06:30 AM
    I don't believe this is possible with IAP on its own.
    You can do it if you've got a controller, or Clearpass!
  • 3.  RE: Time restrict connect to IAP Guest Captive Portal
    Posted Dec 02, 2013 06:31 AM
    Or Airwave...!
  • 4.  RE: Time restrict connect to IAP Guest Captive Portal
    Posted Dec 02, 2013 10:19 AM
    Thanks guys. That's quite a bummer.
    thanks again,
    Blue
  • 5.  RE: Time restrict connect to IAP Guest Captive Portal
    Posted Dec 03, 2013 05:12 PM
    I don't have an IAP to test with but can't you set a time of day on a policy with an IAP? Make the policy deny all (put it at the top of the initial policy) the time range would be nighttime. Deny all would only happen when <nighttime> range is in effect which will not allow users to connect during the hours specified.
  • 6.  RE: Time restrict connect to IAP Guest Captive Portal
    Posted Dec 03, 2013 05:17 PM
    I thought of this route as well and to the best of my knowledge and attempts does not provide the option to set time restrictions.
  • 7.  RE: Time restrict connect to IAP Guest Captive Portal
    Posted Dec 04, 2013 08:45 AM
    I checked on my lab IAP 105 (running v4) before the first response just to be sure. Went in and looked at roles and the raw SSID settings. There's no options for timed access. Only destinations, services, and allow/block etc (no times). Pretty confident this isn't possible on IAPs.
