Time separation solution
  • 1.  Time separation solution
    Posted Mar 03, 2012 06:34 AM
    Hi all,
    My client looking for time separation solution.
    He needs to give access to guest network on one hour for different users.
    He don't want to generate separate users by guest-provisioning.
    If he generates normal user with expiration time 60 minutes, user dissapears after 60 minutes, next user can't enter.
    He don't want external RADIUS.
    Is there any solution ?
  • 2.  RE: Time separation solution
    Posted Mar 03, 2012 06:46 AM
    If you have four separate users and they all login at different times, you will need 4 different users created with the expiry on the controller, just like you are doing.  I do not think there is a way around this.  The controller-based guest access cannot create a user where the access countdown begins when the user logs in.
    Only ClearPass Guest Access (Amigopod) provides the flexibility that you require, with a single user.
  • 3.  RE: Time separation solution
    Posted Mar 03, 2012 07:36 AM
    Thank you !
