the AP will continue to use its last Aruba Central synched configuration when it can't reach Aruba Central.
after AP loses its connectivity to Central (i think it takes around 5 min) it will allow configuration mode on the AP.
So if needed one can login to the AP and modify its configuration.
Original Message:
Sent: Oct 24, 2022 01:54 AM
Subject: Timeout for AP Config after loosing Connection to Aruba Central
HI,
thanks for this Info.
In a Aruba test i had the question after which time the AP restore its full local configuration when it lose the communication with Aruba Central.
(24h,60min,120min,15min)
Thomas
Original Message:
Sent: Oct 21, 2022 06:25 PM
if the AP that is already configure with Aruba Central looses its connectivity to Central, it will just operate as before. it will not reboot.
Original Message:
Sent: Oct 21, 2022 11:52 AM
Hi @ all,
can somebody help me? I can not find a information what will happen when a ap lose connection to Aruba Central.
Do somebody know, how log a AP will wait before it reboot or load local config after losing connection to Aruba Central?
Thx for your help
Thomas
