times of operation
  • 1.  times of operation
    Posted Dec 04, 2013 04:23 PM
    Instant 105 deployment. Customer would like the AP to only be broadcasting (read: 'on') during business hours of M-F 8 to 5.  Can I set when to disable/enable RF or SSID?
    I'm not seeing it off hand, but I very well could be looking in the wrong place.  Thanks in advise to anyone that has input/suggestions.  Thanks much...
  • 2.  RE: times of operation
    Posted Dec 04, 2013 04:32 PM
    This can't be done with the instant alone you will need something ClearPass to send a access policy based on the time of day
  • 3.  RE: times of operation
    Posted Dec 04, 2013 04:34 PM
    I don't think it's possible.  Do you have ClearPass installed?  It is possible with that
