last person joined: 5 hours ago
TLS cert from clearpass
  • 1.  TLS cert from clearpass
    Posted May 03, 2016 02:59 PM
    Hi Forum,
    Is there any way I can generate a user cert manually from cppm onboard admin console and install it on a client device without the quick connect app?? I'm trying to see what other options I have available to distribute cert to some clients.
    thanks,
  • 2.  RE: TLS cert from clearpass
    Posted May 03, 2016 03:03 PM
    Yes. Onboard > Management and Control > View by Certificate > Generate a new
    certificate signing request. Be sure to select TLS client cert.
  • 3.  RE: TLS cert from clearpass
    Posted May 04, 2016 04:50 AM
    As a side note, starting with ClearPass 6.5, you can configure Web based Provisioning to allow 'unsupported devices' to manually onboard. If Onboard detects an unsupported device, it will offer the user to generate and download a certificate that can be installed on the device by the end-user.
    2016-05-04 10_47_16-Provisioning Settings (Arubalab ClearPass 6.6 Onboarding).png
    This might be a useful alternative for the manual certificate creation by the admin.
