TLS CNs and matching with AD usernames
  • 1.  TLS CNs and matching with AD usernames
    Posted Jun 13, 2018 08:01 AM
    I have some Role generation rules that assign specific Roles based upon whether a user is in a specific AD group e.g. "UoY NEtwork Group" role assignment if (Authorization:UoY AD Authentication:memberOf  CONTAINS cn=g0790stf,ou=Inst,ou=Groups,ou=UoY,DC=its,DC=york,DC=ac,DC=uk
    When creating eap-tls client certificates I set up the CN to be "userid-{4 digit hex number}@york.ac.uk"
    This sort of screws up the UoY Network Group Role "as userid-abcd@york.ac.uk" certainly isn't in that AD group.
    Is there any way of using a regex to strip out  my userid from the start of the Full-Username and use that when comparing against contents of an AD group
  • 2.  RE: TLS CNs and matching with AD usernames
    Posted Jun 13, 2018 08:23 AM
    Is the fully qualified username correct in any part of the certificate?
  • 3.  RE: TLS CNs and matching with AD usernames
    Posted Jun 21, 2018 04:28 AM
    Actually the solution was simple ( thanks to the PM I received from an Airheads user). All I had to do was replace
    user:@,\:user
    with
    user:-,user:@,\:user
    in the service processsing the eap-tls stuff
    and it all worked, e.g. for CN=as1558-abcd@york.ac.uk the username becomes as1558, which is what we want
    Rgds
    Alex
  • 4.  RE: TLS CNs and matching with AD usernames
    Posted Jul 03, 2018 07:02 PM
    Thanks for the tip, that may work with a TLS vs. AD username problem I'm facing as well.
