To decrease Virtual controller failover sysc time
  • 1.  To decrease Virtual controller failover sysc time
    Posted Dec 28, 2015 12:42 PM
    I have IAP 205 VC with 20 IAP with latest AOS.
    While Master IAP goes down and new IAP become master, i observed that wireless user connection drop and 5-6 ping drop. Once master elected wireless client asking for credential (Guest self registration)
    How can we decrease master failover sync time/ping drop or how to avoid existing wirless user connection drop?
    Thanks..
    #AP205
  • 2.  RE: To decrease Virtual controller failover sysc time
    Posted Dec 28, 2015 12:52 PM
    The connection for ALL users, or only the users that are connected to the VC drops?
  • 3.  RE: To decrease Virtual controller failover sysc time
    Posted Dec 28, 2015 01:03 PM
    Hi Joseph,
    I observed that for all users and i was pinging VC IP from my desktop system.
    Thanks..
  • 4.  RE: To decrease Virtual controller failover sysc time
    Posted Dec 28, 2015 01:20 PM
    Is your WLAN using a  VC-Assigned VLAN?  In that case, all of the guest traffic is tunneled to the VC, so there has to be a VC election to decide who will handle and nat that traffic.  The minimum failover time should be 10 seconds, really.  If you are achieving 5 seconds, that is good.
    If you were using 802.1x and you had a network-assigned VLAN, the AP a user is assigned to would just keep passing traffic, even during the VC election, because the data traffic would be truly distributed.
  • 5.  RE: To decrease Virtual controller failover sysc time
    Posted Dec 28, 2015 09:52 PM
    I am not using VC assigned vlan for WLAN.
    I hv 2 SSID Employee(vlan 10) and Guest(vlan 20). My network L3 switch leasing IP address for WLAN.
    IAP is getting IP address from vlan 10.
    Do i need to configure saperate management vlan for IAP?
    Thanks...
  • 6.  RE: To decrease Virtual controller failover sysc time
    Posted Dec 28, 2015 11:41 PM
    A best practice is to have a separate management VLAN for your IAP, yes.
