Too Many Frame Errors
  • 1.  Too Many Frame Errors
    Posted Oct 02, 2014 06:49 PM
    Today we get an user with a very slow network connection. Checking on Airwave we see a "Too Many Frame Errors"
    This user is five feet away from AP with line of sign and the connection are at 2.4Ghz
    The network are IAP-105 running 6.3.1.8-4.0.0.7
    This can be a RF interference? We are on a building with a lot of Wifi Networks. Have some way to avoid this?
    Paulo Raponi
  • 2.  RE: Too Many Frame Errors
    Posted Oct 02, 2014 08:11 PM
    If you go to the VC UI it can give you an overview of the RF health of that AP
    You can also run the following command and will let you know if there's a lof of channels or power changes because of interference
    If RF is not the issue you may want to look at the drivers on that device
