TPM Initialization or Certificate Initialization failed
This thread has been viewed 58 times
  • 1.  TPM Initialization or Certificate Initialization failed
    Posted Jun 25, 2013 09:02 AM
    Hi
    on my Aruba 651 controller, after login with the admin account, the following error shows up:
    ====================== E R R O R =======================
    TPM Initialization or Certificate Initialization failed.
    For debug information see /tmp/deviceCertLib.log.
    If this message appears even after rebooting the device
    couple of times, please contact Aruba Networks.
    How can I access /tmp/deviceCertLib.log ??
    Does anyone have an idea what could be wrong here?
  • 2.  RE: TPM Initialization or Certificate Initialization failed
  • 3.  RE: TPM Initialization or Certificate Initialization failed
    Posted Jun 25, 2013 09:38 AM
    (Aruba651) #show tpm cert-info
    Cannot get TPM and Factory Certificate Info.
    TPM and/or Factory Certificates might be missing.
     Does this mean there are problems related to the hardware?
  • 4.  RE: TPM Initialization or Certificate Initialization failed
    Posted Aug 08, 2014 02:39 AM
    Hi
    What happened at last..
  • 5.  RE: TPM Initialization or Certificate Initialization failed
    Posted Aug 12, 2014 10:36 AM
    hi oNek
    This can be due to a corruption of the certs (usually due restoring a backup made with tar flash instead of backup flash between two different controllers) or a failure of the TPM itself.
    The steps you can follow to try and recover are:
    a> collect output of "show tpm error"
    b> write erase all (make sure to take backup using backup flash, copy out licenses etc, or just reconfigure all)
    c> reboot
    If still not fixed, then log a ticket with TAC showing steps a~c above and request RMA due to failed TPM.
    Just to clarify, do not use tar flash for moving configs between controllers, it is purely for Aruba debugging.
    regards
    -jeff
  • 6.  RE: TPM Initialization or Certificate Initialization failed
    Posted Jan 15, 2018 11:40 PM
    gunzip failed on /tmp/collected-tpm.data.gz; error=256Bad magic number in header, secondary bank Both primary and secondary compressed certificates are bad or missing Reboot Cause: User reboot. SKIPPING Generating SSH Keys......0022 done. Initializing TPM and Certificates gunzip: bad block type 3 gunzip: bad block type 3 Performing intra-version configuration upgrade for version 6.4. Saving current config file default.cfg as default.cfg.2018-01-19_23-01-39 Generating new configuration. Configuration upgrade complete. Performing integrity check on Ancillary partition 1...passed. Restoring the database...done. Starting hwMon
