@SethFiermonti wrote:
If you don't use a Mobility Master, then you can run in master controller mode with 2 controllers however, AP termination is NOT supported on the master in 8.x. I would recommend deploying a VM or HW based mobility master.
Hi guys
I have a customer with an environment like that and now they will buy a virtual controller but all concepts for me are a little bit confused.
Today the customer has 2 controllers 7030 (active/stand-by) with 53 AP 115. Now they are buying another 48 AP 205, so these controller aren't able to handle with these new AP because it has AP limitation (64). Now to upgrade and support all AP they will buy a VMC. To create the same topology I will need to deploy a Mobility Master and two VMC ? or deploy two MM ? They will sell the controller 7030.
Tks
Luiz
