Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
Training
  • 1.  Training
    Posted 11 days ago
    Where can I see on demand training.
  • 2.  RE: Training
    MVP GURU
    Posted 11 days ago
    Please check here for available training options:
    https://www.arubanetworks.com/support-services/training-services/
    Also if you have not already, create an account here:
    https://certification-learning.hpe.com/TR/Index.html
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: Training
    Posted 11 days ago
    Thanks!!
  • 4.  RE: Training
    Posted 11 days ago
    I'm new to quotuing Aruba, I know that the devices need a license but in the datasheets I only see the hardware not the license SKU, is there an ordering guide for the license>
  • 5.  RE: Training
    MVP GURU
    Posted 11 days ago
    Are you an Aruba partner? Aruba uses a quoting tool called IRIS which you can build quotes with. It will contain all of the SKU's.
    Dustin Burns
