Transition from controllerless to Controller
  • 1.  Transition from controllerless to Controller
    Posted Apr 13, 2021 10:54 AM
    Greetings:
    In the next few days I have to deploy a demo for an Aruba Controller. The users have implemented an IAP topology on site. Is it possible to use a controller in the same network without it having automaticlly "absorbing" the control of the IAP implementation? My objective is to demonstrate the capabilities on 2 APs, but leave the rest of the IAP implementation alone.
    Thanks in advance
    Pablo Murillo
    Networking engineer
  • 2.  RE: Transition from controllerless to Controller
    MVP GURU
    Posted Apr 13, 2021 11:40 AM
    Yes you can. The IAPs will not convert to Campus APs on their own once they have joined an IAP cluster. You would have to convert them through the Web GUI or CLI.
    Dustin Burns
  • 3.  RE: Transition from controllerless to Controller
    Posted Apr 13, 2021 12:14 PM
    Thanks! Just double checking that I have my theory right
    Pablo Murillo
