Hi all,
I have two IAP's. IAP 205 and 225.
I am testing the quick loss of the Master IAP, and the transparent failover of virtual controller. So i unplugged the master to simulate the loss, the other IAP become master.
When the IAP is re-plugged, as it's configured as master prefered, it returns to master state. The other IAP reboot and came up as slave. This is a normal behavior for me.
The problem is connectivity between master and slave is lost, i can't see slave on VC and i can't reach master from slave.
I think that slave came up with default wired profiles so it can't reach master because it has wired ports configured access when it's trunk on switch.
I have two solutions to retablish connectivity :
- switch config on switch to access and then to trunk when slave has sync with master
- reload slave IAP (i don't understand here why it doesn't work at the first reboot)
Both are annoying when u want transparent failover.
Is there a trick or something i miss on configuration to avoid this ?
Thanks for help
