Translating self-reg guest portals
  • 1.  Translating self-reg guest portals
    MVP
    Posted Jan 18, 2016 06:17 AM
    Using the translation packs and enabling the text ID's I am able to translate alot without having to configure multiple pages. There's a few ítems I cannot seem to translate without creating multiple pages. Surely I'm missing something here?
    For example.. on a self-register page I'm asking the visitor for a few details: phone number, company name, ... However when I turn on the text id's  all these fields show up as id255. This id seems to be the id for required fields so translating that id doesn't do anything.
    If I turn of the requirement I get no id at all.
    For the Register button I have the same issue: no idea is given. If I look at the form field itself I get no futher either, seems no id exists for the actual button text:
    If I can't use the translation pack to translate that text, I will be stuck creating a page for every language right? So what am I missing here?
  • 2.  RE: Translating self-reg guest portals
    MVP
    Posted Mar 13, 2019 07:04 AM
    Old topic but still current..
    Anyone know how to translate that Register button on a selfreg page that in English goes from 'Register' to 'Log' In when the user registers and then logs in?
    When using other languages (tested: Dutch and French) the 'Register' gets translated correctly now, but then after registering it should change to a translation for 'Log In' which it never does.
    And digging rround in translations I'm getting nowhere.
    Hitting the link  [#17403 Override all translations generated for this page] does not give me anything usefull.
  • 3.  RE: Translating self-reg guest portals
    Posted May 22, 2019 08:12 AM
    Running into the same issue.
  • 4.  RE: Translating self-reg guest portals
    Posted May 23, 2019 08:28 AM
    In guest, go to Configuration > Translations > Assistant
    Enable the option "Show Text IDs with text"
    Now, edit the submit field in the Self Registration page.
    Next to the label this is now a Translate button. Overhere you can update the text.
  • 5.  RE: Translating self-reg guest portals
    Posted May 25, 2019 12:26 PM
    Yes, on 6.7+ the Translation Assistant has a new toggle that adds a Translate link to a number of new spots (specifically self-reg and the custom fields and forms).
    One quirk for anyone updating from previous releases is that to inherit the default self-reg translations you need guest_register as a parent.  Anything created from scratch will have a mis-match of translations.  Best to play with guest_register or re-create one with it as a parent.
